please insert the call searching option on label printing.
Call search on label printer option.
73s, Camillo
Re: Call search on label printer option.
Camillo,iz6gvc wrote: 19 Sep 2020, 15:23 Hi,
You can do than now if you tap on the Filters in the Label Print Panel. Use th dropdown to select 'callsign', enter the callsign you are searching for. Tap the "+" button to add that parameter the query window. Close the Filters window and your search of that particular or maybe several callsigns will appear.
Hope this help.
Good morning Nolan!
Yes, your suggestion are very usefull!
Now, with filter application, repliing to QSL arrivated make the job more easy.
Many thanks, Camillo!
73s, Camillo
