Log4OM Version 2 -LoTW download Problem
Re: Log4OM Version 2 -LoTW download Problem
I completed the support request in the "Help" menu selection in Log4OM ver 2.9.
But did you then email me the zip file it generated?ke5td wrote: 28 Sep 2020, 14:24 I completed the support request in the "Help" menu selection in Log4OM ver 2.9.
No, where will I find the zip file ? Send it to your email listed in QRZ ?
Sorry read the manual and looked in the "Help, open config folder" but I don't see a zip file.
When you raise the support request it tells you where the zip file is being saved as the zip file is created, the on screen instructions are all you need to follow.ke5td wrote: 28 Sep 2020, 15:05 No, where will I find the zip file ? Send it to your email listed in QRZ ?
Yes email as on QRZ
This must be beyond frustrating for you and I am sorry. I will try again and see if I can get it right this time.
Thank you Terry for your patience!!
73, Gary
73, Gary
Ok I hope I got the Support request correct and I did email you the zip file.
Thanks, Gary
Thanks, Gary
Update: Problem was LOTW related and not Log4om !!
Terry is AWESOME!!
Terry is AWESOME!!
