Log4OM hangs up on LotW Upload
W6SDM
Post by W6SDM »
I am trying to upload my last 22 QSOs. The upload freezes after the following messages:
INFO: ADIF File created successfully
INFO: TQSL Version 2.5.5
Executing TQSL with upload
and then it freezes. Nothing has been changed, my TQSL and Log4OM have been working together since they were installed and there haven't been any changes to either one. I tried restarting Log4OM and got the same result. My Log4OM version is 2.9.0.0.
Thanks,
Steve
Re: Log4OM hangs up on LotW Upload
Have you tried uploading from the QSL manager?
Turn on trace mode in the help menu, try another upload on closing and then look at the program log to see what happened
W6SDM
Post by W6SDM »
Terry, Thanks for the reply. Before you responded, I tried shutting everything down and restarting each program I was using. No dice. I did a cold start on the computer and that fixed the problem. Something was obviously hung up somewhere. It could have even been RFI causing a port to freeze up. I will keep an eye on it.
Steve, W6SDM
