Label printing issue
F6EXV
Re: Label printing issue
Post by F6EXV »
Terry
May I include myself in this thread ?
I am using labels that are 70mm wide, 35mm high, page A4, 3 columns, 8 rows, top margin 5mm, bottom margin 5mm, no space between labels (neither vertically nor horizontally) = they are contiguous.
My printer is a Brother MFC-8380N (laser, black ink only)
No need to reply so quickly, this is Christmas Eve ! You deserve many big presents from Santa Klaus (he has received the Covid vaccine...)
Thanks + 73
Paul F6EXV
F6EXV wrote: 24 Dec 2020, 16:34 Terry
Is the stationery Avery or some other brand and does it have a reference number?
Also what about left and right margin sizes?
Perhaps a graphic to illustrate what is going wrong? Difficult for me to understand from these posts
F6FLU
Post by F6FLU »
Hello Terry
Make : ETIBOX
Ref No : 119756
Labels per sheet : 14
Number of columns/rows 7 rows (42,5 mm) and 2 Columns (105 mm)
Label size / 105mm x 42,5 mm
Margin and spacings : 0
Printer make and model : Brother MFC-J6530DW
Thanks ...
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
Another reference is
Make : ETIBOX
Ref No : 119753
Labels per sheet : 16
Number of columns/rows 8 rows (35 mm) and 2 Columns (105 mm)
Label size / 105mm x 35 mm
Margin and spacings : Top Margin : 0,80mm Bottom margin : 0,9 mm
Dan - F6FLU
https://F6FLU.org
I dont think I can solve your issues without a sample of the label stationery
Is it possible for you to trace around each label with a ball pen and then scan and post it here as a pdf file? that way I can compare the resulting print out against your stationery.
Also post your attempts at producing label templates on this forum
Please also confirm that you BOTH have the same issue where the test print is OK but a live actual label print from your logbook does not match the test print?
F6EXV
Post by F6EXV »
Terry
I have given full info on how labels are on the label page.
So my label width is 70mm.
BUT the second label (going to the right) is not 70mm apart, but a little less, the third one is again a little less. So it actually start printing on the second one.
My label height is 35mm.
Gpoind downwards, the second row will be slightly less then 35mm from the 2nd one, and so on, so the top line gets closer and closer to the ^revious row, and even prints on it.
Thanks + 73
Paul F6EXV
F6EXV
Post by F6EXV »
I have tried to scan an example, but the site here says the file is too largen so I cannot attach it.
I am sending it to you by email, hoping you do not mind.
Thanks + 73
Paul F6EXV
F6FLU
Post by F6FLU »
Make : ETIBOX
Ref No : 119756
This is my template :
My Page layout :
Log4OM Settings Labels Page Layout 2020-12-25 093426.jpg (63.28 KiB) Viewed 3735 times
My label properties :
Log4OM Label properties 2020-12-25 093747.jpg (23.47 KiB) Viewed 3735 times
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
I print the Test File PDF from the page layout
20201225083851.pdf
(4.07 KiB) Downloaded 195 times
The same with the drawing of the labels (not precise drawn by hand) just to see that there is indeed a vertical offset of the labels
that the printing on the left begins "in the void" and that the right column begins just on the line. It is therefore necessary to give margins so that all this is coherent. so i will then show my margins settings
Dan - F6FLU
https://F6FLU.org
F6FLU
Post by F6FLU »
Now I set margin and save my template :
Page Layout margin 03 2020-12-25 095904.jpg (57.94 KiB) Viewed 3733 times
we see that now on the left part everything is well written, we also see that there is always a vertical shift and that on the right column we print well on the right label
Dan - F6FLU
https://F6FLU.org
