Export CSV File
F6FLU
Export CSV File
Post by F6FLU »
Via the menu "QSO Manager I want to export some QSOs that I have selected in a file in CSV format
I select some fields that interest me and especially the "iota_island_id" (or "iota") field AND the "state" field
and I export in CSV Field
I look at the file generated by Log4OM :
Log4OM export CSV file Pb 2020-12-30 171447 copie2.jpg (197.6 KiB) Viewed 3293 times
as you can see Log4OM ignores this field altogether
whereas the penultimate "STATE" field Log4OM does indeed create an empty field ;; when there is no data
obviously it shifts my entire database :-)
thank you in advance if you can look at the problem
Dan - F6FLU
https://F6FLU.org
Re: Export CSV File
If there is no data in the record a CSV file should always include the separator for the empty field
Seems there could be a code issue will check
F6FLU
Re: Export CSV File
Post by F6FLU »
Hi
yes I detected this problem with the IOTA field but I did not check if it is happening with other fields,
I don't think so because in the first record (YU5FF) there is indeed an empty field generated for the STATE field which does not exist
For information if the IOTA field exists then Log4OM exports it well
Export CSV with IOTA Field 2020-12-31 164939.jpg (40.89 KiB) Viewed 3259 times
Dan - F6FLU
https://F6FLU.org
F6FLU
Re: Export CSV File
Post by F6FLU »
Is it possible to know if this problem has been taken into account and if it will be corrected in a new version ?
Thanks and 73
Dan - F6FLU
https://F6FLU.org
Re: Export CSV File
As I said we will check the code and it's on our Mantis list of issues
If you need to know what has changed in a release check the release notes in Help/about/release notes
Re: Export CSV File
Fixed in 2.12.0.0
Thanks for reporting
F6FLU
Re: Export CSV File
Post by F6FLU »
Thanks Daniele
Dan - F6FLU
https://F6FLU.org
