SQLite Database max QSO
VK6KC
Post by VK6KC »
I have Log4OM V2.11 with SQLite which shows as max 5,000 QSO (I'm near that limit).
I have the following questions;
1. Is there a way to extend that 5,000 limit or do I need to create a new database and if I need to create a new database (presumably with yet again max 5,000 QSO's) how does the program track "worked before" and "Awards" across the different databases?
2. Alternatively should I just create a MyQSL database (export/import QSO's) and be over and done with it?
Thanks,
Kurt - VK6KC
Re: SQLite Database max QSO
VK6KC wrote: 06 Jan 2021, 06:50 I have Log4OM V2.11 with SQLite which shows as max 5,000 QSO (I'm near that limit).
Thanks,
Kurt - VK6KC
This is not the maximum number of QSO's in the SQLite database the number your refering to is the number displayed - Please read page 27 of the Log4OM user guide.
SQLite is good for up to around 130000 QSO's depending on the efficiency of your PC
VK6KC
Post by VK6KC »
On the Recent QSO's (F7) tab - bottom right hand corner you can see this;
Selected 1 of 4955 (my actual QSO count) and next to it max: 5000
Also, page 27 of the User Guide is about Managing Layouts (latest V2 guide from website).
I'll see what happens when it ticks overt the 5000 mark...
Kurt - VK6KC
Unless you change the value it will say the same because it refers to the number displayed not the number of QSO's in your database
So if you have 25000 QSO's and the value is set to 5000 only 5000 will be displayed although look up will be done on 25000
If you change the value to 50,000 then it will display all 25,000 QSO's
If you change the value to 100 it will display the last 100 contacts of the 25,000
VK6KC
Post by VK6KC »
OK, thanks for the clarification of that.
Kurt - VK6KC
F6EXV
Post by F6EXV »
Hi all
terry
The first solution you indicate does not work. There is a red message saying "No QSO selected"
Second solution does work.
By the way, any operation I do where a refreshing is required, on my database of 55,000+ QSO, takes ages. Is this normal ? (using Log4OM 2 v2.11.0)
Thanks + 73
Paul F6EXV
F6EXV wrote: 07 Jan 2021, 08:45 Hi all
terry
Not sure what first solution you refer to?
Try reducing the number of QSO'S viewed by default as detailed on page 27 》》》 of our user manual, you don't need to view every qso in the grid so a thousand is probably more than enough
