At ADIF imported QSO-s the country is not recognized
ha5nx
Post by ha5nx »
Dear All,
I have imported an ADIF log - after a contest for which I used other application - and at most of the QSO-s the country is not recognized based on callsign.
As you can see on the attached picture, for the country is recognized for some of the QSO-s but for most of them not. The problem is not with the callsign, because if I begin to enter a new QSO with that callsign, the software recognizes the country.
And the not recognized countries are also not shown in the "Statistics and awards" menu as worked countries - if they were not worked before on the band already.
Of course I can one all the QSO-s one by one and enter the country - but for more than 200 QSO-s I would like to find a more "comfortable" solution.
Thanks for any help in advance,
73!
HA5NX
Gabor
Re: At ADIF imported QSO-s the country is not recognized
You failed to state which contest program the ADIF was created in, however send me the contest log ADIF file by email and I will check it to see what happened
Send to g4pop (at) arrl.net
ha5nx
Post by ha5nx »
Sorry, it was N1MM Logger+ but I have just sent you the ADIF file via mail as you asket.
Thanks and MNI 73!
I will check it
But in future please use the correct integration of N1MM with Log4om, no adif required your N1MM QSO'S will be added to Log4om in real time and updated automatically, see our user guide for instructions
Gabor,
Checked your N1MM ADIF file and imported it without any problem
How did you import the ADIF file EXACTLY?
What version number of Log4OM are your using (Help/About)
ha5nx
Post by ha5nx »
Hi
I imported it using the menu option: File -> Import ADIF
The version of Log4OM is 1.41.0.0
There were no error report during the import, but - as you can see on the screenshot - at most of the QSO-s the country is not recognized
I was thinking about trying to import them again but I was afraid of getting doubled QSO-s
ha5nx wrote: 21 Jan 2021, 19:44 Hi
Then you posted in the wrong forum, this is the version 2 forum, I will move the thread!
I tested with version 2 and it all works fine
Best thing you can do is an update of those QSO's in QSO manager, see version 1 user guide for how to do that.
Version 1 is only on maintenance, why have you not updated to version 2?
ha5nx
Post by ha5nx »
Sorry, but I didnt even know that there are versions 1 and 2
If I check in Help->Check for new releases, I receive the message "You currently have the latest version"
ha5nx wrote: 21 Jan 2021, 19:54 Sorry, but I didnt even know that there are versions 1 and 2
Of version 1 you have the latest release
If you update Please, Please, Please read our user guide instructions about how to update
