I have been using Log4OM for a few weeks and its amazing. the problem im having is.......when I download QSL from eQSL and LoTW I am not sure how to resolve QSO not Found messages. I am getting many confirmations so the process is working but im not sure how to resolve the ones that dont end up matching.
this is one example:
Begin FULL ADIF generation request
Login ab6kx
Begin ADIF download. May take some time...
RESPONSE file downloaded...
Parsing FULL ADIF file...
ADIF FULL document parsed: 83 qso found.
QSO NOT FOUND : WA0RIM|1/17/2021 10:50:14 PM|20m|OLIVIA
SAVING FULL QSO's...
SAVE COMPLETE
LOTW UPDATING STATISTICS...
LOTW END
thanks in advance.
Dave
AB6KX
Downloading eQSL and LoTW
Re: Downloading eQSL and LoTW
Hi Dave,
if you see messages like this you must open the contact in the QSO manager and check
on eQSL and/or LotW site where are differences. I got things like this if time or date
are wrong, if the upoloader has a wrong mode used or if you logged him with an extension
like /P, /M or /MM but he confirms without this.
To check this out it´s handmade work, HI.
As an expample my contact with a /P station which operates with /P but confirms without:
Please post in the correct area, your post is being moved to the version 2 section
thank you much for this lead. for this QSO the other operator put the mode as Olivia and I put it as Olivia 8/250. i will review the others and see what I find. I will post more info if I run into trouble.DF5WW wrote: 26 Jan 2021, 06:52 Hi Dave,
To check this out it´s handmade work, HI.![]()
