French Departments
F6FLU
French Departments
Post by F6FLU »
when looking at the detail of a QSO with a French station ( Edit QSO / His Details)
we can add the name of the department in the "state" field and that's fine ...
BUT :
the departments are not sorted in alphabetical order and therefore it is very difficult to validate the department
Detail Dpt non triés.jpg (51.96 KiB) Viewed 3487 times
I did not look at everything but also it is not Hautea-Pyrénées but Hautes-Pyrénées
Hautea Pyrenées.jpg (53.06 KiB) Viewed 3487 times
you can find the official list here
https://fr.wikipedia.org/wiki/Liste_des ... n%C3%A7ais
but I propose the following changes:
- Add the department number before the name for example 78 - Yvelines
in fact the French people use numbers a lot and not the official name ...
for example for the contest "cup of the REF" we pass this department number
- Be able to sort on this department number OR sort on the Department name
Thank you beforehand if you will take these remarks into account.
and if you could confirm (or not) if you will take this request into account ...
Dan - F6FLU
https://F6FLU.org
Re: French Departments
Did you consider editing and sorting the order yourself in the 'states.csv' ? sort the entries for DXCC 227 alphabetically A-Z in a spreadsheet
In case you cant find the file its at C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2
F6FLU
Post by F6FLU »
OK Terry I modified the name in this file but
in the file it is well ordered
it is in this display that it is not ordered
Detail Dpt non triés.jpg (51.96 KiB) Viewed 3481 times
Dan - F6FLU
https://F6FLU.org
f4bkt
Post by f4bkt »
Hi Terry , Dan
The reason is simple,
In France Ain = 01 and not 1 as in the "states" file.
the order thus becomes 1,10,11,...... 2, 20, 21
And not 01, 02, 03 ......
This also applies to other countries such as Croatia.
Each time the state starts with "0".
This worked before in the first versions 2
Following an update, this change appeared (I can't remember when).
The "0" is no longer taken into account.
73 Philippe
F6FLU
Post by F6FLU »
I modified the States.csv file like this :
Log4OM States.csv.jpg (43.05 KiB) Viewed 3423 times
and now it works well (at least as I want :-) )
Dan - F6FLU
https://F6FLU.org
