Frequency: Includes RIT…????
Re: Frequency: Includes RIT…????
he is saying that its incorrect and you should use freq A or B but which one and what happens when he changes VFO?
i'm using this function because i can get VFO A, VFO B, RIT or CURRENT FREQUENCY (intended as the current active VFO)
Moving to VFO A or VFO B means i know what is the VFO in use, that is another call to the xml-rpc service provided by Hamlib.
Another way is to sum/remove RIT from current frequency, but again it's another call.
Need some time to get rid of that... and i need someone with 2 VFO in the radio for tests
Hi Lele
I have four VFOs with flex6500 !
If you need some test with 2 of them (A an B) let me know
73 de Don IK2EGL
I can't find a function to get current vfo and this is a problem...
I'm all tutorials from omni rig I saw the same function I used.
I'm trying to have an answer from Alex, omni rig author
Got answer, working on...
Solution is not included in 1.17 RC1, working for it on RC2 to be released
