ADIF Export Pb
F6FLU
ADIF Export Pb
Post by F6FLU »
I have a problem with the full export in ADIF
I have these QSOs on the Logbook :
the latest QSOs are
A25RU 10M CW
VK9CE 20M SSB
UC6IM 20M CW etc..
Then I export all QSOs to an Adif File :
As you can see VK9CE 2021-03-21 at 15:12 then A25RU 2021-03-21 at 16:00
there it is OK then we go back to R2ZA 2021-03-20 at 14:10 and then resume the correct order with RA3MD 2021-03-20 at 14:11
Why are the 2 QSOs placed in the middle of these QSOs and not at the end?
Dan - F6FLU
https://F6FLU.org
Re: ADIF Export Pb
Why is it such an issue?
Any software that you import the ADIF to will sort in in whatever order is required e.g. by date or mode or band or by call sign.
F6FLU
Re: ADIF Export Pb
Post by F6FLU »
Hi terry
No, it's the software that exports that must sort by date not the one that receives, well that's my opinion ...
Dan - F6FLU
https://F6FLU.org
Re: ADIF Export Pb
F6FLU wrote: 22 Mar 2021, 13:25 Hi terry
Not true
We see many ADIF files which are exported from other software, some are in order others are not
Anyway as you say its your opinion!
