Cluster display is blank
n6oil
Post by n6oil »
Something got buggered on my cluster display, I can connect successfully to the servers and I see the telnet updates but on my main screen F8 the window is blank. Does anyone know what's up? Ver 2.12.0 WIN 10 box.
Re: Cluster display is blank
n6oil wrote: 06 Apr 2021, 02:11 Something got buggered on my cluster display, I can connect successfully to the servers and I see the telnet updates but on my main screen F8 the window is blank. Does anyone know what's up? Ver 2.12.0 WIN 10 box.
Rory,
What do you observe when you have your Cluster Management panel open? Raw data under the Management tab? Data under the Cluster tab? How many servers do you connect to under the Connection tab?
What cluster commands do you have saved when you log into the cluster?
Have you looked at your V2 log file? Help / Open Log File There might be some clues there as well.
Any change to visible data on the Cluster (F8) tab after a restart of V2?
Check that you dont have some cluster filters set
n6oil
Post by n6oil »
Bloody filters, yup that was it. Stupid schoolboy mistakes! Thanks all.
