JT8
F6FLU
JT8
Post by F6FLU »
I don't understand, I still have JT8 selected in my preferences, even if I uncheck it and save, if I open the preferences again JT8 is selected again
and whatever the number of selections in "Preferred bands" or in "Prefered modes" I always have 0 Items selected
Thanks for your help
Dan - F6FLU
https://F6FLU.org
Re: JT8
I assume that you have added JT8 to the mode list yourself because its not in the standard list because its not an ADIF mode see http://adif.org.uk/311/ADIF_311.htm#Mode_Enumeration
F6FLU
Re: JT8
Post by F6FLU »
Hello terry
YES this is more than likely
I guess I need to edit the file "AppData/Roaming/Log4OM2/modelis.csv and delete this JT8 mode ?
PS : I have another question about RTTY but I will open another post so as not to mix up my problems :-)
Dan - F6FLU
https://F6FLU.org
Re: JT8
Easier to use this from the Settings menu
F6FLU
Re: JT8
Post by F6FLU »
Done
Thanks Terry ...
Dan - F6FLU
https://F6FLU.org
