V 2.12 broke IC-746
V 2.12 broke IC-746
After loading ver.2.12 My IC-746 will no longer connect. The freq comes up in the second window and radio goes nute. All versions prior to 2.12 worked perfect. You all broke something with this upgrade. It was perfect before you upgraded the selection to IC-746 Stable. Go back to the old driver..
Re: V 2.12 broke IC-746
Did you try reverting to version 2.11.0.0?
Are you using Hamlib, if so why not try Omnirig?
Yes I had go back to 2.11 to make it work again, but that kind of defeats the purpose of having a upgrade available. When you upgraded the 746 beta to the 746 stable version is when it got broken.
Hamlib or Omnirig?N7WEJ wrote: 04 Apr 2021, 16:14 Yes I had go back to 2.11 to make it work again, but that kind of defeats the purpose of having a upgrade available. When you upgraded the 746 beta to the 746 stable version is when it got broken.
Hamlib. I have always used Hamlib with the IC 746 since Omnirig would never connect from the beginning. Now Hamlib will no longer connect with the 746 starting with ver 2.12. All previous versions worked perfect using Hamlib prior to 2.12.
Hamlib had a few bugs in its latest update, which we included with version 2.12.0.0 of Log4OM, we are assured that the Hamlib problems have now been resolved and the updated version will be included in our next release.
