Hi,I tried uploading a log to LOTW but the it said that no QSO was uploaded or duplicate.The call sign is not showing on LOWT so it's not a duplicate.Not sure what I'm doing wrong.
This is what it said:
No records to upload
Final Status: No QSOs written(8)
All QSOs were duplicate or out of date range (no QSOs written)
LOTW END
LOTW Upload
Re: LOTW Upload
Have you also tried to upload manually with ADIF export from Log4OM and manual upload
via TQSL ? If not please try to do so and tell us the results please.
Re: LOTW Upload
I corrected the grid square.I had it wrong on the TQSL.I don't know how it worked before but it is fixed.Now I have this when I tried uploading again:
The Station Location 'US County' has value 'New Haven' while QSO has 'United States' on line 10
I fixed it in configuration and it still says the QSO has U.S. in county line.Don't see anything wrong on TQSL when I check my profile.
It did upload when I entered it manuelly via TQSL but when I tried uploading the adif File I created in LOG4OM it didn't work.
Thanks Rich
73 KB1FGC
73 KB1FGC
Re: LOTW Upload
I fixed it.What happened was,Even though I updated my station information in configuration.When I saved the QSO earlier it was saved with the wrong settings.After I updated the settings in the QSO section it worked!
Thanks for the email
Thanks Rich
73 KB1FGC
73 KB1FGC
Re: LOTW Upload
You have posted in the version 1 forum, are you in fact using version 1 or the latest version 2 which was released early 2020?
