Version 2.14 is available for download here
Installed version https://www.log4om.com/l4ong/release/Lo ... 14_0_0.zip
Portable version https://www.log4om.com/l4ong/release/Lo ... rtable.zip
Release note – Version 2.14.0
[NEW] Contest interface has been removed. All functions are now managed by main interface
[NEW] Winkeyer user interface has been rewritten for a more coherent layout
[NEW] When connected to CWSkimmer telnet server (Enable "CWSkimmer commands" in the CWSkimmer 'Settings' window) Log4OM is able to detect and lookup callsign/frequency on click
Added contest mode switch on main UI
Main UI logics rebuilt to reduce code complexity and improve reactivity and reusability of routines
F12 key now clears QSO data entry
Added contest fields in main UI (visible when contest mode is active)
PSE/TNX QSL moved to country row on label print, to avoid overlap with long QSL Messages
Added CTRL-S to save QSO in LazyLog / CTRL-R to clear interface
Typing a callsign in the winkeyer TX area and pressing Return key will set the callsign in the lookup area without transmitting anything.
[FIX] Fixed winkeyer macro issue that send truncated text
[FIX] Fixed datagrid export in XLSX that stopped working on some systems due to an updated library
[FIX] Fixed an issue with Clublog exceptions that consider the value valid if expired less than 90 days ago
[FIX] Fixed an issue and improved routines on award recognization for QSOFIELDS award types that prevented correct automatic identification of some references.
[FIX] Fixed random issues on application shutdown related to LOTW upload
Log4OM Version 2.14 released
