Hi, Just downloaded the software but am unable to get the WCF connection to work. Running Vista, have enabled admin rights but will not connect. Settings - services has WCF services stopped, clicking green start button and nothing happens. I am ok but not the best with a pc, any advice please.
Regards
Tony
WCF connection
Re: WCF connection
Hi Tony, we usually ask users to register with their call, so we can provide a more precise support, if possible from the same time zone
Please check your log file, you can open the folder with files the latest of help menu.
If Log4OM has troubles connecting via wcf is usually a antivirus issue.
If your log report "actively refuse" the connection probably the point.
New release will not use wcf anymore between communicator and Log4OM, keeping wcf for external services, but a firewall will block tcp also.
Please check log and let us known
Daniele IW3HMH
Daniele IW3HMH
Re: WCF connection
Hi Daniele and thank you for the reply. No log shows when I go to help/show log, not sure if that is the reason it will not connect. All other features seem to work.
Would it be a good idea for me to re-register under my call sign?
Regards
Tony MW0TBP
Regards
Tony MW0TBP
Re: WCF connection
I will change your username into your call.
Version 1.16 has a known bug on the show log
You must use the show config folder function and open the log subfolder. You will find here all the logs. Thanks and welcome
Re: WCF connection
Hi Daniele, Thanks for the help. Looked in the log and found this entry...
014-04-02 16:08:04.0630 INFO: FormSettings: WCF SERVICE Start request issued by user
2014-04-02 16:08:04.2110 INFO: WCFManagement: RunServices starting with path localhost:8080/log4om
2014-04-02 16:08:04.2130 DEBUG: WCFManagement: using HTTP http://localhost:8080/log4om
2014-04-02 16:08:05.6720 INFO: WCFManagement: Opening
2014-04-02 16:08:07.0060 INFO: WCFManagement: Faulted
2014-04-02 16:08:07.0310 ERROR: *** WCFManagement: RunServices start exception ******* [Function: RunServices] System.ServiceModel.AddressAccessDeniedException: HTTP could not register URL http://+:8080/log4om/. Your process does not have access rights to this namespace (see http://go.microsoft.com/fwlink/?LinkId=70353 for details). ---> System.Net.HttpListenerException: Access is denied
at System.Net.HttpListener.AddAllPrefixes()
at System.Net.HttpListener.Start()
at System.ServiceModel.Channels.SharedHttpTransportManager.OnOpen()
--- End of inner exception stack trace ---
I have turned anti virus off but still no joy, sorry I have had to come back with same problem.
Regards
Tony MW0TBP
Regards
Tony MW0TBP
Re: WCF connection
Tony,
It seems that you are not running Log4om as an administator.
Full instructions of how to do this are in the user manual
Re: WCF connection
Thank you Terry and Daniele, thought I had sorted the admin bit out, working now and I could kick myself. Want to set it up with Fldigi next but not tonight!
Looks a great programe and I am looking forward to seeing it all up and running, thanks again both for the help.
Regards
Tony MW0TBP
Regards
Tony MW0TBP
Re: WCF connection
Hi Tony,
That's good news
FLDigi setup is covered in the user guide but if you have problems let us know
That's good news
