Info in "Worked bands" window missing
OH3FVP
Post by OH3FVP »
When I click the callsign in JTDX, all data in the Main UI is correctly populated except the country/band info in "Worked bands" window (see attached picture). This stopped working after I installed the latest version 2.14.1.0.
73 de Teemu OH3FVP
Log4OM Screen Capture.PNG (79.73 KiB) Viewed 2151 times
PE5TT
Re: Info in "Worked bands" window missing
Post by PE5TT »
same here
N0GJR
Post by N0GJR »
I too began experiencing this as reported above. First noticed with v2.14.0 and later with v2.14.1.0
LA7EIA
Post by LA7EIA »
Same problem here, the worked band statistics only works if I manually enter callsigns after the update.
At first i thought it was only related to JTDX, but the same problem is present if you click a callsign in the DX cluster window. Everything is updated correctly, except the Worked bands window.
73 de LA7EIA Erik
