v2.15.0.0 Upload to LOTW no longer works
LX2KD
Post by LX2KD »
Trying to do a TQSL upload to LOTW, either manually or as part of a shutdown routine, no longer works. I get a popup box like this:
Any ideas what to do about it?
73s
Kevin
LX2KD / G4AZO
Re: v2.15.0.0 Upload to LOTW no longer works
What's your TQSL version?
It seems your TQSL is not supporting the new "-f UPDATE" command provided by the last generation TQSL software.
LX2KD
Post by LX2KD »
Ciao Daniele,
The upload window says TQSL version 2.4.7. Final status is "Command Syntax Error(10). It has been working OK under Log2OM version 2.14 (and previous) until I did the upgrade to 2.15.
Kevin
LX2KD / G4AZO
LX2KD
Post by LX2KD »
It's OK now thanks. I see from the LOTW web site the current version is 2.5.7. I updated and it seems to be OK now. Could I please suggest that the release notes for 2.15.0.0 should mention that TQSL should also be updated.
73s
Kevin
Kevin, we are not supporters of TQSL. Each user of TQSL has to start it from time tio time
to check that he has the latest version of TQSL and/or the TQSL configuration file. I do this
one time each month and not only when my tq6 file has expired.
Release Notes in Log4OM are release notes for Log4OM itsself and that is what "Release Notes"
standing for.
Yust my 2 cts ... ;) ;)
n3xl
Post by n3xl »
Yesterday I upgraded to the new TQSL and everything seemed fine and my contacts uploaded. Today Log4OM2 screen just freezes upon exiting with following text frozen forever:
Uploading LOTW data (120 seconds timeout)
Saving form status...
Shutting down...
Bill N3XL
n3xl wrote: 05 Jul 2021, 03:40 Yesterday I upgraded to the new TQSL and everything seemed fine and my contacts uploaded. Today Log4OM2 screen just freezes upon exiting with following text frozen forever:
Shutting down...
Bill N3XL
Did you try a manual upload?
DB9CR
Post by DB9CR »
Same behavior here, Log4OM 2.15.0.0, TQSL 2.5.7
Manual upload:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.7
No private TQSL Password set
Executing TQSL with upload
then nothing happens
DB9CR wrote: 05 Jul 2021, 07:28 Same behavior here, Log4OM 2.15.0.0, TQSL 2.5.7
Manual upload:
Well I just tested the upload both manual and automatic on closing and both worked fine so its something wrong at your location.
Perhaps you could follow the trouble shooting route as detailed for sending a support request on page 230 of the user guide to Lele?
DB9CR
Post by DB9CR »
Support request generated according to Manual, page 230. Last instruction: "Send the ZIP file to the provided email address." What address has been provided to me? ;-) Thanks in advance.
