Statistics
m5aec
Re: Statistics
Post by m5aec »
Now we have both screenshots, 2nd showing, despite England showing in entry
screen, the Cluster highlighted country is showing in the statistics panel.
And 2.15. is showing as the version, top left.
sorry again for the messy submission (88 years might explain)
Barrie m5aec
Re: Statistics
Well the statistics are showing OK on two of your screen shots but the first is empty, perhaps post a screen shot of the 'Filters' pane
m5aec
Re: Statistics
Post by m5aec »
Apologies for previous, put it down to 88 years!
I have just noticed that if you get the statistics
panel up in the Main (F6) then it does change with
an 'off air' as opposed to 'off cluster' callsign entry!
Barrie m5aec
m5aec
Re: Statistics
Post by m5aec »
Terry I think you will find that the two screen shots showing OK
are the ones with HB highlighted in the cluster and Switzerland in statistics, but G in callsign entry panel,
whereas when there is no cluster entry highlighted then the statistics
show blank despite G entry in callsign entry panel.
Regards Barrie m5aec
m5aec
Re: Statistics
Post by m5aec »
Having discovered the Statistics panel in Main (f6), i can now state problem more clearly.
Stats panel in Main(F6) shows stats for whatever is in the callsign entry panel,
whereas Cluster(F8)only shows Stats for what is highlighted in Cluster listing.
If it not actually intended I would regard it as extremely useful for both Statistics
panels to operate similarly as I tend to remain in Cluster screen permanently.
Thanks for your patience
Sorry it has been so longwinded.
Re: Statistics
m5aec wrote: 04 Jul 2021, 12:15 Having discovered the Statistics panel in Main (f6), I can now state the problem more clearly.
I would regard it as extremely useful for both Statistics panels to operate similarly as I tend to remain in Cluster screen permanently.
Then you should post this request in the Feature Requests section of the forum
