Bonjour,
Depuis la dernière mise à jour LOG4OM ne se ferme plus - la fenêtre de fermeture reste ouverte - je suis obligé de faire un fin de tache - Y a t -il une solution pour régler se problème - Merci
fermeture log4om
fermeture log4om
73 de F1ubw - Manche 50
Re: fermeture log4om
Rivet,F1UBW wrote: 25 Jul 2021, 15:08 Bonjour,
You noted you have the most current release of Log4OM V2, but you did not note the ID of same. The current version is V 2.15.0.0 so just want to confirm that.
Do you have your configuration set to to an auto-upload to LOTW when you close down Log4OM V2?
If that is the case why don't you go into your configuration and turn that item off and see if it makes any difference when closing down Log4OM V2.
As it relates to LOTW what version of TQSL do you have installed? The most current version is: V 2.5.8
You could update to the most current TQSL and then re-enable the auto-upload of LOTW when Log4OM V2 closes to see if that makes any difference.
Ok KI5IO Nolan
Merci des conseilles - cà a marché
Bien vu ... TQSL n'était pas à jour -
Maintenant tout va bien
Merci beaucoup - au plaisir sur les ondes - peut être sur 20 m
Rivet,
Tnx for the follow-up and the 'thank-you'. Certainly is most appreciated.
