Hi
I'm trying to move my QSOs fra Log4OM V1 to V2. I export an adif (version 3) from V1 and then i import it into V2.
But i get the message: "QSO not valid. Skipping import."
I can see that MODE is missing in the adif, that must be the problem, i think?
What can i do?
Soren
MODE is missing in adif file
Re: MODE is missing in adif file
The import routine has a log file, if you save it and then copy and paste one example of the log entry for one skipped QSO here I should be able to tell you what to do.
You could of course update the missing modes in V1 before exporting the ADIF file.
Hi Terry
Thanks for your fast repply.
I solwed the problem. I installed V1 on the same PC as V2 and now there is no problem.
Soren
Soren
