My References Not Showing Up
Re: My References Not Showing Up
KJ7EHA wrote: 15 Aug 2021, 19:36 So should we log this to the "Error Reports" Forum?? I sure miss this feature.
Greg,
If you will note above in a post I made ... this issue is on our Mantis list for repair.
Currently Danielle is on holiday and this (along with other items) will be looked into when he gets back.
NR3E wrote: 02 Aug 2021, 19:21 Thanks to the team for all your great work. I had hoped this issue would be fixed with the latest release. Do we know if it is scheduled for a fix soon?
Thanks,
Ron, NR3E
Ron,
Not until Danielle gets back from holiday. I think that is around the 20th, but I'm not certain of that date.
KJ7EHA
Post by KJ7EHA »
Thank you for fixing this feature! I loaded latest version and I once again can see the "Contact References" and "My References" data items in my view. I appreciate having this capability.
wb2bin
Post by wb2bin »
What does the "my references" do? I have noting set in my configuration but there are lots of things I am finding out that i did not check when I started using the program.
Thanks,
Greg, WB2BIN
wb2bin wrote: 06 Sep 2021, 11:27 What does the "my references" do? I have noting set in my configuration but there are lots of things I am finding out that i did not check when I started using the program.
Thanks,
Greg, WB2BIN
Greg,
Do a search for "My References" in the current User Guide. Many notations in there about items related to same.
Here is a link to a YouTube Video that Terry provided that also shows how you can use My References.
https://www.youtube.com/watch?v=0u5CHJom2YY
wb2bin
Post by wb2bin »
Thanks Nolan
