DXCC Challenge
Moderator: OE6CLD
G3ZSS
DXCC Challenge
Post by G3ZSS »
In the Award Status, I can select the DXCC Challenge, but if I look at the statistics window, all I see is the individual band totals. How does one get to see the actual DXCC Challenge total?
73 Peter G3ZSS
Re: DXCC Challenge
Hi Peter,
Basically you cant and its an issue we have had on Mantis for some time but at the moment this lockup issue that affects some users has our full attention
DB9CR
Re: DXCC Challenge
Post by DB9CR »
I also found this problem.
My workaround is clublog - it gives a good overview about worked DXCCs, but course knows nothing about the QLS cards received, only LOTW.
So if there are resources, calculating the challenge points correctly would also be interesting for me.
Thanks in advance
Christian DB9CR
KI5BLU
Re: DXCC Challenge
Post by KI5BLU »
Hi - just wondering if this is still on the list. I'm still on V1 since it has a great DXCC Challenge summary stat which is missing from V2 ... would love to switch to V2 ... any timeline of when you think you might be able to add this?
Tom KI5BLU
Re: DXCC Challenge
KI5BLU wrote: 13 Sep 2022, 16:27 Hi - just wondering if this is still on the list. I'm still on V1 since it has a great DXCC Challenge summary stat which is missing from V2 ... would love to switch to V2 ... any timeline of when you think you might be able to add this?
Tom KI5BLU
Tom,
I've put a fresh note on the Mantis item for this and have tried to bump it up in the queue.
KI5BLU
Re: DXCC Challenge
Post by KI5BLU »
Nolan - thanks so much, really appreciate it!
Greetings from Southlake ... 73
Tom KI5BLU
