Using version 2.15.0.0.
I inadvertently left 'SATELLITE MODE' checked on the 'My (F4)' tab after a couple of QSO's on QO-100.
I can edit the QSO to clear the satellite name and mode but I'm unable to delete the Propagation Mode which displays 'Satellite'.
Is there any chance that a blank entry is available in the drop down list to correct the Prop Mode?
Cheers,
Andy
Unable to delete Propagation Mode
Re: Unable to delete Propagation Mode
Why not delete it in the QSO manager?
Why are you using an old version?
Because I was unaware of a newer version.
[/quote]
You must be overlooking the notification button (yellow triangle or blue circle) that provides you with notifications each time you turn on Log4OM V2. A left click on the button will provide you with information about a new release or other d/b updates.
Not sure how you have been missing this.
- Notification Button.JPG (44.44 KiB) Viewed 2996 times
Tried that as well, I can't do it there either.
Really?
OK, I'm able to edit the QSO in the QSO Manager so that works as expected, not sure what I was referring to earlier.
In the 'Recent QSO's' tab clicking on a QSO brings up an 'Edit QSO' box, maybe my interpretation of the word 'Edit' is slightly different to others...
Cheers,
Andy
Cheers,
Andy
added "blank" valuee to SATELLITE MODE dropdown list in EDIT QSO screen
That's it! Simples...IW3HMH wrote: 01 Nov 2021, 12:17 added "blank" valuee to SATELLITE MODE dropdown list in EDIT QSO screen
Grazie!
That 'blank value' appears to have disappeared in v2.21.1.0
Download the most current Beta release ... https://www.log4om.com/download/
