Deleting Log4OM and associated config files
ws7x
Post by ws7x »
How to do a complete removal and clean install of log for om?
Tried windows 10 add/remove program but a re-install still uses corrupted config files.
Noel
Re: Deleting Log4OM and associated config files
Uninstall Log4OM. If the program folder exist after the uninstall delete it manually.
Check in C:/Users/Username/AppData/Roaming for a Log4OM folder and delete it
also.
Restart PC and install Log4OM again.
Sometimes a better idea to rename, rather than delete, the Log4OM folder in C:/Users/Username/AppData/Roaming because it might have something you want later like backup files.
Cant you use an old Config file from the backup folder to overcome the issue?
ws7x
Post by ws7x »
Deleting the folder did the trick and I was able to do a fresh install and start a new configuration.
Thanks much!
Noel
