Log4OM 2.18.0.0 don't import ADIF files
EA7KJE
Post by EA7KJE »
Hello all, on the last update I have to import some ADIF data but Import button does not made nothing.
This has been tested on two differents computers with the same result.
Thank you so much!!
Fernando Gomez - EA7KJE
[email protected]
Spain
Re: Log4OM 2.18.0.0 don't import ADIF files
Perhaps you had a corrupt download it works for me
Screenshot 2021-11-15 232119.png (114.1 KiB) Viewed 4370 times
EA7KJE
Post by EA7KJE »
Well I don't know but what does not work is the function of the import button... This don't do nothing after press "Import" and consequently the data on file has not been readed. I don't know if I not described correctly.
This is something that I and my friends have made sometimes when by example we have forget launch Log4OM but we made some contacts with WSJT-X.
Anyway I have downloaded the new version again, installed and tested again with the same result. Ahm and I have tested this on the computers of my friends via TeamViewer on where they or I download her owns new version software, so mine is not a problem of downloaded corrupted files, I have not used my downloaded file.
I have tested this with two file extensions like .adi and .adif...
Rename the ADIF file to "Test.adi". Could be possible the filename is too large.
EA7KJE
Post by EA7KJE »
Renamed but still happen the same... nothing!!
vk1di
Post by vk1di »
Same problem for me. A simple adif file with 1 entry, clicking on Import does nothing. It used to work fine until this update.
Well its working here so send support requests to lele or me
vk1di
Post by vk1di »
Emailed Lele a support request, along with a sample test.adi file.
73 Ian VK1DI
IT9QGH
Post by IT9QGH »
Hi, also I have encountered the problem after replacing the version V2.17.0.0 with that Version 2.18.0.0
so after installing and finding myself without my contacts I had to redo a new database and then change my name.
Only then did the IMPORT button do everything normally.
PA2TA
Post by PA2TA »
I did some testing for someone with the same problem and it seems that this problem only occurs with an ADIF that only contains one record (QSO). In that case version 2.17 works as expected, but in v 2.18 nothing happens.
I tried the same with an ADIF with 2 records and then the import works in both v2.17 and v2.18 without any problems
How many records were there in the ADIF you were trying to import?
