Receiver Frequency Display Accuracy When Using Cluster
N8HO
Post by N8HO »
When I click on a spot shown in the cluster, my radio will tune the given frequency but offset by 700hz. When I double click on the spot the second time the frequency matches the spotted frequency. What should I change so the frequency displayed on my radio matches the spot on the first try?
Re: Receiver Frequency Display Accuracy When Using Cluster
N8HO wrote: 03 Dec 2021, 23:32 When I click on a spot shown in the cluster, my radio will tune the given frequency but offset by 700hz. When I double click on the spot the second time the frequency matches the spotted frequency. What should I change so the frequency displayed on my radio matches the spot on the first try?
Howard,
You have enabled Offset in the CAT section in Configuration. See image below.
N8HO
Post by N8HO »
I checked my configuration CAT settings. The offsets are set at zero.
What?
Log4OM version
Radio
Type of interface
Windows version
Other software is running
Type of spot, Mode, Band etc
N8HO
Post by N8HO »
Thank you for addressing my question. Here are some details.
Log4OM2 Version 2.18.0.0
Windows 10
Yaesu FTdx3000 using the USB port
Other software running - PstRotatorAZ, Omni-Rig 1.19 & Dimension 4
The 700hz frequency variance occurs when spotting on any band while switching from a CW spot to a SSB spot or vice versa. For example, when spotting a station on 7017.000 the receiver will move to 7017.700 on the first attempt. On the second double click it will tune to 7017.000. When spotting from one CW spot to another CW spot the receiver moves to the proper frequency. Same results when moving from one SSB spot to another. The error only occurs when changing modes.
N8HO wrote: 04 Dec 2021, 20:23 Thank you for addressing my question. Here are some details.
Windows 10
Howard,
Take a look at the screen clip I provided above. Try ticing or un-ticing the options regarding inverting SSB / CW, etc.. There are a few options to test and see what works best for your rig.
Check the poll interval in Omnirig, set to lowest value
iz2rlo
Post by iz2rlo »
HELLO
I can not see the frequency in the second VFO
I use ICOM 7800 omnirig microkeyer II
thanks
N8HO
Post by N8HO »
I tried setting the poll interval to the lowest setting which is 100ms. This change had no effect on the display discrepancy. I then checked two boxes in the Configuration CAT screen as shown below. Doing this fixed the issue I was having.
Invert SSB side (CW)
Send MODE before FREQ to radio
G4SEN
Post by G4SEN »
Hi
I've read through a number of posts/threads on this subject and attempted all the suggestions regarding the settings on the CAT management. None seem to work for me.
Running an FTDX10 with OmniRig. Single click in the cluster screen populates the fields ok, a double click moves the rig and log4om to the frequency, but if it's a different mode (ie ssb to cw) there's a frequency difference to the frequency listed in the cluster (700hz offset). Another click aligns to the correct frequency. Changing back from cw to ssb shows the same discrepancy.
