Adding Comment field to Worked B4
NN0TE
Post by NN0TE »
I work a lot of POTA and need to be able to quickly determine if I have worked a station at a specific park - I note the specific park of the POTA station in the comments section so that if the station moves to another park (or two) during the day, I can work him again and get additional credit.
Is there any way to add the comment field to the worked before tab (f10) ?
In other words - If I type a call into the program, Log4om will indicate I've worked it before, I then press F10 to see a list of my prior contacts with that station. Is it possible to add the comment field to that window?
Thanks for a fantastic logging program - easily the best out there.
Trent
NN0TE..
Re: Adding Comment field to Worked B4
Yes see our user guide, right click on column title and select edit from menu
NN0TE
Post by NN0TE »
Thank you very much!
Trent
NN0TE..
