Hi,I had to do a clean install and everything seems good with the program but everytime I save my file it doesn't save a .adi file but only saves a sqlite file or a .json file.I loaded my original sqlite file but it didn't seem to keep the settings that I saved to it but at least my logs are in the program.Is there a way to save the setting so that the columns in the log section stays as preferred?
.adi file issue
.adi file issue
Thanks Rich
73 KB1FGC
73 KB1FGC
Re: .adi file issue
Hi Terry,My .adi files aren't saving in my folder,only the .json or .sql files.Can you tell me what is happening?
Thanks Rich
73 KB1FGC
73 KB1FGC
Re: .adi file issue
Normally you would save the config.json and an sqlite file here unless you changed it C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\backup
And enable additional backups in a folder of your choice, perhaps in the cloud
Check your config for locations as below
Re: .adi file issue
Hi Terry.Maybe there is a glitch or something.I do save it in a different folder so I can access it easily and then back it up to my USB flash drive.I did that before but after I reinstalled the software and set the backup drive to my folder that I want.It saves but only json and sql files.No adif files which isn't too good.I tried saving to files and still not showing Adif files in the folder.Should I do a new install?
Terry,check my 2 screen shots.One is where I save my files.It says Backupfiles/LOG4OM,The other is what the program defaults to.See what you think.
thanks73
thanks73
- Screenshot (2).png (165.06 KiB) Viewed 1433 times
- Screenshot (1).png (219.71 KiB) Viewed 1433 times
Thanks Rich
73 KB1FGC
73 KB1FGC
Re: .adi file issue
You had not checked the 'Additional backups' box which is the one to save an ADIF
