SIOTA - Silos On the Air Award
Moderator: OE6CLD
vk1di
Post by vk1di »
I've created an award template for SIOTA - Silos On The Air. It reads the SIG_INFO field to find Silo QSOs
Attached SIOTA.zip. The award website is https://www.silosontheair.com/home
73 Ian VK1DI
SIOTA.zip
(16.22 KiB) Downloaded 716 times
VK2YW
Re: SIOTA - Silos On the Air Award
Post by VK2YW »
Thanks Ian,
Well done and works a treat. Now to go back and update my SiOTA contacts :D
John 2YW
vk1di
Post by vk1di »
Seems more Silos have been added recently.
Updated zipped SIOTA Award .xml attached
73 Ian VK1DI
SIOTA2.zip
(15.77 KiB) Downloaded 734 times
vk1di
Post by vk1di »
Another SIOTA Silos update, zip file attached.
73 Ian VK1DI
SIOTA20220331.zip
(13.42 KiB) Downloaded 674 times
VK2SKI
Post by VK2SKI »
Could some kind person please explain how I use this to get SiOTA working in log4om?
I have tried importing to no avail
TIA
Malcolm
Malcom,
First off I want to extend my TNX to Ian for building this Award and also updating the added References. That is most appreciated Ian. TU ...
Malcom - First d/l the zip file and save to your local SSD or HDD in a folder where you might have other awards saved.
Unzip the SIOTA.XML file that is inside and note where you have unzipped and stored the SIOTA.xml file.
Then ... Turn on Log4OM and go to: Utilities / Award Manager
Then go to: File / Import Award
You will then direct that window to where you have unzipped and saved the SIOTA.xml file. Left click once on the file and let it import into Award Manager.
If you scroll down in the Available Awards Column you will note the SIOTA award (with a green square) and you are now set to go.
Once you have that accomplished go to: Settings / Configuration / Award Preferences
You will see the newly loaded in SIOTA award in the right column and you need to left-click on SIOTA and move it to the left column. Then ... tap "Save and apply". Once you do that you should see the SIOTA award in your Award drop-down list.
