Calling back hidden detached windows.
CT1BXX
Post by CT1BXX »
I would suggest the possibility of calling the detached windows that had been hidden for any reason whenever we click on the working area of the Log4OM window.
Is that possible? this would help immensely :D
73 Manuel Fernando CT1BXX
Re: Calling back hidden detached windows.
Manuel,
I can see all open/hidden windows when I hover my cursor over the Log4OM icon in the Task Bar.
Would that not help?
For this test I put the BandMap behind the Main UI. Hovering over the Task Bar Icon all three open windows appear. Two are visible to begin with and the BandMap was hidden.
CT1BXX
Post by CT1BXX »
Hi Nolan,
Many thanks for your comment.
I also use it, however we need to click one by one if Iwant all them in front.
The idea is : calling the UI window, then all the others hidden would come into the front at same time.
I am a lazy men :D :D :D
Manuel,
I did a little bit of research on this quite some time ago and also got some input from a couple OMs who had used the Windows manager for their needs.
I don't have any personal knowledge about the information, but have put the links below for you and others to review and see if such might work for your personal needs. At least until such time that your request makes it way through the possible 'to do' list of features.
Ten Forums Tutorial on Snap Windows
https://www.tenforums.com/tutorials/434 ... -10-a.html
DeskSoft Windows Manager
https://www.desksoft.com/WindowManager.htm
WinSize2 - SourceForge:
http://winsize2.sourceforge.net/en/
