New user, legally blind and have a question or two
NT4TC
Post by NT4TC »
Hey folks,
I'm just getting back into amateur radio after a 5 year hiatus (only operated for about 3 months even then).
So I'm looking at a couple different options for logging.
#1 Question currently: Does Log4OM support sending CW via a single USB cable into my Yaesu FTDX-10? I've been able to get HRD and N3FJP to work. There are two com ports.. one for cat control and the other for the DTR sending.
I look forward to hearing from you and I'm sorry for the newbie question.
Tom - NT4TC
NT4TC
Re: New user, legally blind and have a question or two
Post by NT4TC »
Buehler?
Sorry for the delay I have been unwell and its slowed me down a lot.
No CW via separate USB is on our list
However we do support USB Winkeyer by K1EL if you have one
NT4TC
Post by NT4TC »
Thank you Terry. I hope you're feeling better.
2nd question... If I choose 'Contest' input...
1. Can I control what fields are visible for input?
2. Can I control the order in which they're tabbed through? (do i just put them in that order?)
3. Does that create a separate log or just use my master log?
(well I guess that was the 2nd, 3rd and 4th questions)
Tom - NT4TC
Tom
1. No
2. No
3. You can use a seperate log if you like but it's not neccessary because log4om will show worked before only for stations worked in the contest if you use the main log
