Searching QSL's
KB1FGC
Searching QSL's
Post by KB1FGC »
Hi,I attached a file so you can see what screen I'm on.I can't seem to select between certian dates when searching QSL's.If I uncheck the boxes for date the range,I think I get the entire log.When I check the selected days,I don't get anything. I do know that there are qso's between the dates though.
Thanks for the help
I have 2 attachments,One with the sent dates checked, and one without the sent dates checked.
Screenshot (31).png (77.82 KiB) Viewed 1131 times
Screenshot (30).png (81.93 KiB) Viewed 1131 times
Thanks Rich
73 KB1FGC
Re: Searching QSL's
Rich,
Do you mean (in your search) to be looking for the Q's with the "requested" upload flag?
It appears (from your images) that you have changed that in Config/External Services so that "no" is used instead of "requested".
That being the case I would change the Sent Flag to a blank or a No or a Yes, etc., etc..
Just a thought anyway as the Flag for the LOTW column is not visible in your screen clip. I'm guessing only due to the yes/no I see for the other External Services.
KB1FGC
Re: Searching QSL's
Post by KB1FGC »
Thanks for reply.I think I figured it out.
Vy 73
Thanks Rich
73 KB1FGC
Re: Searching QSL's
KB1FGC wrote: 21 May 2022, 15:46 Thanks for reply.I think I figured it out.
Vy 73
Rich,
And ??? Your solution?
Will be helpful for other OMs who might run across similar.
Tnx in advance.
