Hopefully these are two simply requests. At Award > DXCC > Statistics ... the layout gives us a good snap shot of our performance. Can you insert a blank line between the major categories such as the overall wrap-up of Worked-thru-Granted -- CW -- Digital -- Phone. That will give us some eye relief and better see categories as groups.
Also I attempted hiding some of the columns because I do not operate 1.25m, 70cm, etc. I right-clicked on, in this case, 70cm and then selected Edit Table Layout. Then I get a red box error message saying "Edit not available. Grid contains dynamic fields." Therefore I can not deselect any bands. Is there a way to deselect bands from appearing on the spreadsheet?
FYI -- Using Log4OM2 NextGen version 2.23.0.0. Using a Dell XPS 8930 running Windows 10 Pro - version 10.0.19041 Build 19041 - 64 bit w/Intel Core i7-9700 CPU @ 3 GHz.
Thanks and have a good day.
Danny
AH6FX/W4 - Virginia, USA
Statistics
Re: Statistics
Remove the unwanted bands in the 'Awards filters' tab as below or for a more permanent solution edit the award in the Awards manager
Re: Statistics
Thanks Terry. Easy!
Danny
AH6FX/W4
Danny
AH6FX/W4
Re: Statistics
Danny
Danny
