Edit label print
on6at
Edit label print
Post by on6at »
First of all I am using version 2.23.0.0 with windows 11.
I want to print my qsl labels.
Via Utilities you can go to labels definition. There you create your label and it will be saved in your folder.
Via Utilities I go to Label print and indicate my qso's that need to be printed.
Everything runs smoothly, but after printing I notice that the layout is not as I saw in the test via label definition.
What I determined was the following;
- If you press Print via label print, you also get the option to go to edit via step 1: label choice.
- So at EDIT you can update your label, which you have chosen here by Select label.
But I found that this didn't work well.
Example:
1) Step 1: label choice > Select label: the first label is Avery L7159 and the second label is Gallery 11035 105*35mm
2) I choose label 2, so Gallery 11035 105*35mm and press Edit.
3) The Label definition window opens. But at load label I see my first label, so Avery L7159
4) I changed this to my 2nd label Gallery 11035 105*35mm
5) I adjust my label a bit, such as Corrective factor, Interline or QSO per label.
6) Via the Page layout tab, I can click on the flopy disk next to Name of the label.
7) The program has given me a warning that the label already exists asking if it can be overwritten.
8) I click OK
9) I now get the message "label saved with name user_Gallery 11035 105*35mm" and click on OK.
10) I now have to close the Label definition window itself.
11) I also close the Label print window just to be safe.
12) I start over with "Utilities" > "Label print" and choose my QSOs.
What happens after this edit?
The settings I just saved, so Gallery 11035 105*35mm is still my old settings. The program has NOT used the new settings that I modified. :o
Is this a bug or is something else going wrong?
Or do you have to close LOG4OMv2 completely before you can read the new settings?
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Re: Edit label print
Patrick,
Did you select the label you saved with the "user_" prefix on it?
on6at
Post by on6at »
Hi Nolan,
I found my mistake.
I see now that I have a new label name with User_Gallery 11035 105*35mm instead of 2_Gallery 11035 105*35mm
Shame I didn't find this. HI
Thank you for the tip.
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
on6at wrote: 23 Jul 2022, 20:38 Hi Nolan,
I found my mistake.
WHEW!!! :D
Great to hear and see!!
Will be helpful, I'm sure, for other OMs as well.
Tnx for sticking with it.
