Default Radio 1 and 2
on6at
Post by on6at »
I am using 2 different radios with CAT in Log4OMv2 Version 2.23.0.0 With Windows 11.
1st radio Yaesu FT-950 with the antenna Cushcraft R8 from 40m to 10m standard.
For the 80m I use the same radio but with the G5RV antenna.
2nd radio Yaesu FT-897D with a commet X300n antenna.
This for 144 and 430 Mhz.
Now comes my problem which I identified.
You can switch in your CAT window between radio 1 and radio 2
That goes good.
But if you make your window F4 'My (F4)' visible, when I switch between both radios, I see that the radio settings don't match the type of radio and antenna being used at that moment.
The settings are 'default' for radio 1 Yaesu FT-950 and its antennas.
You can only specify 1 radio as default.
But using the same logbook with 2 radios (HF) and (VHF/UHF) still requires 2 defaults?
See my attachments
Is this a bug?
A_Default Radio 1_2.jpg (73.93 KiB) Viewed 653 times
B_Default Radio 1_2_logscreen1.jpg (145.81 KiB) Viewed 653 times
C_Default Radio 1_2_logscreen2.jpg (145.52 KiB) Viewed 653 times
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Re: Default Radio 1 and 2
You have to change the radio and aerial manually there is no function for automatic swap
on6at
Post by on6at »
Maybe in the future foresee this.
I have seen my wrong info several times already. HI
But thanks for your info.
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
