I have L4OM set up to receive UDP updates from N1MM, which normally works fine.
My issue is with the Worked All Europe contests, where you can send or receive QTCs - lists of up to 10 previous QSOs, which also count for points. Unfortunately these QTC lists also appear in the feed, which complicate the log, and are also sent out to QRZ, Clublog and so on.
Is there any way to make L4OM ignore the QTCs - or alternatively stop N1MM adding them to the feed?
Tim
How to ignore WAE QTCs from N1MM
Re: How to ignore WAE QTCs from N1MM
Which fields are these appearing in in Log4OM? perhaps a screen shot?
N1MM+ logs each QTC as a sent QSO (for scoring purposes), and it shows up on their UDP feed.
Technically it IS an actual QSO, and it should show up in your station log, I suppose.
If its sent as a QSO and not just the QTC content to a field there is nothing we can do, its up to you to delete them if you dont want the record
N1MM+ records it as a QSO in their log, so I'd expect it probably also treats it as a QSO on UDP.G4POP wrote: 25 Aug 2022, 07:00 If its sent as a QSO and not just the QTC content to a field there is nothing we can do, its up to you to delete them if you dont want the record
