Hi
I can use Log4OM Cat control with Omnirig to the IC-735 or WSJT but not at the same time.
I guess it's because you can only use one open com port at a time.
So is it the general idea you open the com port in WSJT but not Log4OM.
CAT Control with WSJT
Re: CAT Control with WSJT
If you like to use the multithreading of Omnirig you must run all softwares as Adminitrator.
That means, Log4OM, WSJT-X and Omnirig must be "Run as Administrator". That´s also
described in the User Manual and i think in Terry´s Youtube Videos too.
And select OMNIRIG in WSJT not your radio, please read our user guide
