Not responding
oh6ih
Not responding
Post by oh6ih »
Hello!
I have used Log4OM2 about a week and several times got error Not Responding and a few qsos not automatically logged.
What can I do / something re. settings_
Windows OS Windows 7 Ultimate 64 bit Version 6.1 Build 7601> Service Pack 1
Processor and ram type ACPI x64-based PC, Intel Core i5 CPU 650 3 20GHz 8 GB
Log4OM release number 2.23.0.0
Release numbers of associated software JTDX ...160
Radio make and model Yaesu FT/950
CAT Interface RigExpert TI3000
Cat control type (Hamlib or Omnirig) Hamlib
73 Alf OH6IH
73 Alf OH6IH
Jakobstad, Finland
Re: Not responding
oh6ih wrote: 27 Aug 2022, 10:41 Hello!
73 Alf OH6IH
Alf,
Do you have an updates or are you still experiencing what you have noted?
If so ... Try using Log4OM with only a connection via CAT to your Yaesu FT/950. Do NOT connect any other ancillary programs such as JTDX, WSJTx, etc..
When you operate Log4OM in that fashion what are your results?
Are you able to make/save QSO without the FTxx APPs connected? IE: via CW or SSB?
You did not explain what QSOs and how you are making and attempting to save them.
If you are only referring to FTxx QSOs being made by JTDX are you also using JTAlert or Gridtracker or using JTDX via a "direct" connecting without those other two APPs?
If that is the case I'm going to guess that you have some configuration / setup issues that are not properly set.
Regardless ... let's step back and trouble-shoot one layer at a time.
Review above and advise.
