LOTW upload error keeps repeating
M0MDS
Post by M0MDS »
Recently I noticed LOG4OM was not uploading correctly to LOTW, it was hanging when you shut down LOG4OM trying to do something.
I turned on the more verbose version of the logging and it reported an error on TQSL "Already Uploaded QSO suppressed on line 9....
Giving me a choice to Ignore or cancel.
The QSO in question was from a long time ago, it looks like LOG4OM is trying repeatedly to upload the QSO.
I deleted the QSO from the log and it is still doing it, I have no idea where it is even storing the QSO ?
Please can you help?
Mike
M0MDS
# Log4OM 2 by IW3HMH version 2.20.0.0
# http://www.log4om.com
# created: 13 September 2022
<ADIF_VERS:5>3.1.0 <PROGRAMID:7>Log4OM2 <PROGRAMVERSION:8>2.20.0.0 <eoh>
<CALL:6>SV3AUW <BAND:3>30m <MODE:3>FT8 <QSO_DATE:8>20211230 <TIME_ON:6>183030 <ADDRESS:39>108 Lakonikis St. Kalamata 24133 Greece <A_INDEX:1>7 <ANT_AZ:1>0 <ANT_EL:1>0 <CONT:2>EU <COUNTRY:6>Greece <CQZ:2>20 <DISTANCE:7>2398.14 <DXCC:3>236 <EMAIL:20>[email protected] <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>R <FREQ:9>10.137780 <GRIDSQUARE:4>KM17 <ITUZ:2>28 <LOTW_QSL_RCVD:1>R <LOTW_QSL_SENT:1>R <MY_CITY:6>London <MY_COUNTRY:7>England <MY_CQ_ZONE:2>14 <MY_DXCC:3>223 <MY_GRIDSQUARE:6>IO91wo <MY_ITU_ZONE:2>27 <MY_NAME:10>Mike Field <MY_POSTAL_CODE:7>N22 7AZ <MY_RIG:6>IC-705 <MY_STREET:19>4 St Saviours Court <NAME:13>Takis Perreas <OPERATOR:5>M0MDS <OWNER_CALLSIGN:5>M0MDS <STATION_CALLSIGN:5>M0MDS <PROGRAMID:7>LOG4OM2 <PROGRAMVERSION:8>2.20.0.0 <QSL_RCVD:1>R <QSL_RCVD_VIA:1>E <QSL_SENT:1>R <QSL_SENT_VIA:1>E <QSL_VIA:53>No paper QSL pse! Lets keep it electronically simple! <QSO_COMPLETE:1>Y <QSO_DATE_OFF:8>20211230 <QTH:8>Kalamata <RST_RCVD:3>-10 <RST_SENT:3>+01 <SWL:1>N <TIME_OFF:6>183159 <TX_PWR:2>80 <K_INDEX:1>2 <LAT:7>37.0388 <LON:7>22.1208 <MY_LAT:7>51.6042 <MY_LON:6>-0.125 <MY_ANTENNA:5>BTV-6 <QSO_RANDOM:1>Y <SFI:3>111 <EOR>
Re: LOTW upload error keeps repeating
Mike,
Two things I would do:
Update to the most current version of Log4OM v2.
Update to the most current version of TQSL.
Try your uploads after those two APPs have been updated.
M0MDS
Post by M0MDS »
I have upgraded TQSL to the latest version.
I am running LOG4OM v2.20.0.0 It doesn't offer me an upgrade.
M0MDS
Post by M0MDS »
I have manually updated to v2.23.0.0
Still getting same issue. I am assuming the entry has not been marked as sent and LOG4OM keeps trying to upload it.
Can I edit the db somehow to fix it?
Mike,
QSL Manager and select LOTW and you can edit the items as you need.
M0MDS
Post by M0MDS »
When I do that, the item doesn't appear.
I search on the callsign and get other QSO's with the same callsign, but not the one causing the issue.
Probably because I deleted the QSO in order to fix the issue. The deleted QSO is probably still in the Database, but now "hidden"
M0MDS
Post by M0MDS »
I browsed the sqlite db using DB Browser and confirm that the rogue entry is still in the database, but presumably one of the fields marks it as deleted. I could delete the entry in DB Browser but I don't want to break any indexes etc.
Export your log to an ADIF file, use the full export then import that ADIF to a new database
M0MDS
Post by M0MDS »
OK so I exported to ADIF and re-imported to a new database, and all seems fine now.
Thankyou for your support, (and great logger)
Mike
M0MDS
