Is there the option to change the colors in the CAT control when you get out of the band.
example: QRV at 12m on 24940 GREEN CAT control and you turn your vfo to 24995 and then this becomes RED Cat control.
This would be better if you don't keep looking at your Band Map.
Colors change outside the band
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
Member UBA-IPA
WCA: ON-01354
Re: Colors change outside the band
No its hard coded to comply with the regional bandplans
