Upload QSO LOTW bloccato
Italian language forum v2
IZ7AUH
Post by IZ7AUH »
Ciao a tutti,
ho spesso questo problema, resta bloccato upload dei QSO su LOTW a "Executing TQSL with upload" perchè?
Allego screenshot.
Re: Upload QSO LOTW bloccato
Try two things:
- Make sure you are using the most current version of Log4OM V2 V 2.24.0.0
- Make sure you are using the most current version of TQSL. V 2.6.5 / Config Date V 11.20
Then give the upload a try.
I tried to zoom in on your JPG, but can't make out the Log4OM Version number and I think the TQSL v is 2.4.??
Always helpful and we always ask for you to list the current ID versions of Log4OM and all other APPs being used when asking for support.
EI2GLB
Post by EI2GLB »
I am getting the same issue, just seen this after starting my own thread,
I'm using 2.24.0.0 and latest TQSL 2.6.5
Trevor
