Persistent update notification to Log4OM 2 – 2.24.0.0
VK4IM
Post by VK4IM »
Hi
FYI - Just this morning (November 29th, 2022) I started getting a notification that Log4OM 2 – 2.24.0.0 is available for download. I (was) already running that version.
Could this be a reference to the new Log4OM 2 – 2.24.0.5 BETA version released on the 25th I thought?
So I installed the BETA version. However, even with the BETA version installed I still get the update notification for Log4OM 2 – 2.24.0.0
Running Windows 11 fully patched
Cheers, Adam
Re: Persistent update notification to Log4OM 2 – 2.24.0.0
All in the user guide but here it is
N1FG
Post by N1FG »
Happening here also - and Terry the errors are:
A) That the upgrade message indicates the "new" upgrade version is the same (non-BETA) version already running;
and
B) The configuration file is set to NOT show BETA upgrade availability.
Larry N1FG
Log4OM upgrade error config.jpg (110.22 KiB) Viewed 1757 times
Log4OM upgrade error.jpg (163.73 KiB) Viewed 1757 times
ei6kw
Post by ei6kw »
Same here. Only Check for updates active in Program Settings.
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
Fixed! Lele had changed it but the change did not work as expected
VK4IM
Post by VK4IM »
Thanks Terry
Works good now.
I knew it wasn't in the user guide because I checked ;-)
Cheers
Adam
VK4IM wrote: 29 Nov 2022, 22:52
Page 179
VK4IM
Post by VK4IM »
Hi Terry
I think you are miss-understanding the problem.
Every time I start LOG4OM it wants me to upgrade, yet the version I am running is newer than the upgrade recommended.
Problem is still present
Cheers Adam
Screenshot 2022-12-01 094855.jpg (101.53 KiB) Viewed 1658 times
Screenshot 2022-12-01 094928.jpg (67.71 KiB) Viewed 1658 times
VK4IM wrote: 30 Nov 2022, 23:56 Hi Terry
Cheers Adam
As I stated in an earlier post its been fixed but you will not see the result until we do the next release
