Weather option
kp4hf
Weather option
Post by kp4hf »
Any way to disable the weather option? I don't use it.
Thanks.
Re: Weather option
Did you mean the Space Weather with A, K and the sunspots ? If yes there is no option to switch off. It´s hard coded in the main UI.
It´s an oversight for interested Hams and most of us find it useful.
Re: Weather option
kp4hf wrote: 06 Dec 2022, 03:33 Hello,
Thanks.
Did you try checking the user guide? ------ Page 185
Uncheck box at top labelled ''Enable weather engine'
ve3wej
Re: Weather option
Post by ve3wej »
unchecking the box does not stop the f11 weather tab from displaying here. I suggest may , since it is for cw, that it be moved to the cw window,
I wont ever use it here
Dave ve3wej / ve3ie
Re: Weather option
ve3wej wrote: 07 Dec 2022, 00:31 unchecking the box does not stop the f11 weather tab from displaying here. I suggest may , since it is for cw, that it be moved to the cw window,
Dave,
The F11 WX tab will remain on the Main UI, but it will not be refreshed with data when you un-tic the box.
If you prefer that the entire F11 tab be elsewhere put together a proposal and post in the Feature Suggestions portion of the Forum. With a good pitch, Lele might give that a consideration.
kp4hf
Re: Weather option
Post by kp4hf »
See attached picture for the option/tab. And yes disabling does not remove it.
Thanks.
Re: Weather option
It is not primarily for CW its for reference during any mode and many of us will use it when having a phone QSO, it will remain unless there are a large number of users objecting to its presence.
