Old version to use?
Pa0ply
Old version to use?
Post by Pa0ply »
I was used to have a log4om version in which it loaded the log from wsjt when you start log4om.
There was no need to run log4om at the same time you run wsjt while operating.
Can you advice which, older, version I should download?
Thanks in advance,
Jan, PAoPLY
Re: Old version to use?
Nothing has changed you must have been using our ADIF monitor to read the WSJT ADIF file instead of the recommended integration method.
So no nothing changed just use the latest version 2.25.0.0
Pa0ply
Post by Pa0ply »
I used the recommended link setup: upd inbound…. Wsjt_direct port 2237
This was also set in the wsjt-x settings
But when I start log4om, it doesnot read the log from wsjt-x.
Should I setup differently to automatically import QSO’s from WSJT when I start Log4OM?
Br. Jan
The ONLY way log4om will import historic qso's from wsjt is by using ADIF monitor, NOT UDP
Pa0ply
Post by Pa0ply »
Can you give me instructions how to setup for this using wsjt-x, please.
Thanks in advance,
Jan
See our user guide re ADIF monitor
Pa0ply
Post by Pa0ply »
I looked in there, of course, but where to find the adif file in wsjt-x.
Using search it did not find those files in the wsjt directory.
Br. Jan
Should be shown in wsjt preferences I expect but I don't use wsjt only had it installed long enough to write our user guide and then removed it
C://user/username/appdata/local/wsjt-x
the file is called wsjtx_log
DF5WW wrote: 10 Dec 2022, 06:39 C://user/username/appdata/local/wsjt-x
It will be something like WSJT_log.adi not the .log or .ini files
