Nothing in the drop down for Contests
N9BBE
Post by N9BBE »
I'm probably overlooking something. I was going to put LOG4 into contest mode for the ARRL 10 Meter contest this weekend. I went to Contest Settings to select the contest and the drop is blank. The file that has the list of contests is in the proper place it looks like. Anyone else seen this anomaly. I'm using Ver 2.25.00. on a Win 10 machine. Thanks
Re: Nothing in the drop down for Contests
Yes I can confirm this even though the contest file is present for some reason its not being loaded.
I will speak to lele
iw5akt
Post by iw5akt »
I too have the same problem.
73 de Claudio iw5akt
Log4OM 2 V.2.35.1.0
Windows 10
Kenwood TS-480 SAT
N9BBE
Post by N9BBE »
Thanks Terry. You guys are the best.
sp5ah
Post by sp5ah »
Which file is it and where is it located?
It´s the contest.csv file but it´s the same as in former versions. There is something wrong in the Main UI that it not will be loaded i think.
The file is in the Log4OM folder in c://users/username/appdata/roaming/logom2
KG5KRZ
Post by KG5KRZ »
Mine was working until I updated to t2.25.0.0. Now I have the same issue. So, following...
sp5ah
Post by sp5ah »
I confirm. In the previous version, i.e. 2.24.0.0, the file is loaded and the drop-down list is full.
'73
Again! we are aware of this and it will be fixed, no need to keep reporting the same issue!
N9BBE wrote: 10 Dec 2022, 01:41 I'm probably overlooking something. I was going to put LOG4 into contest mode for the ARRL 10 Meter contest this weekend. I went to Contest Settings to select the contest and the drop is blank. The file that has the list of contests is in the proper place it looks like. Anyone else seen this anomaly. I'm using Ver 2.25.00. on a Win 10 machine. Thanks
The contest file was corrupt here is a replacement to overwrite the old file with in..
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2
Dont forget to restart Log4OM after saving the file as above
contest.csv
(8.87 KiB) Downloaded 237 times
