Yes, I got it working!
First I used the import adif function to import existing calls in the wsjt directory.
Then we tested whether or not should Log4om be on, while running qso’s in WSJT-x.
The answer is YES.
log4om will not import existing qso’s from wsjt-x when you start log4om after wsjt-x is running.
From my memory it happened with my former set-up, but maybe I’m wrong.
Anyway now my digital EME qso’s will be in LOG4OM from now on.
Thanks for yoursupport.
Old version to use?
Re: Old version to use?
Thanks all, I found the log file and used import function to add those QSO’s.
We also found Log4OM should be on, while running QSO’s in WSJT-x.
Br. Jan
Br. Jan
