Hi,I have created mutliple logs for different events.I can't figure how to have the .adi file show the name of the event.I name it under the .SQL file and it shows up under database connections,But when saved to a folder it only says my call Mycallsign.ADI,Not the name of the logbook that I want.Is there a way to name the .ADI directly?Thanks
Name ing files
Re: Name ing files
Your confusing the adi backup files with the database for main logbook in your post, what are you actually doing????
Anyway why different files when you can define the event QSO's using the event call sign as the 'Station Call sign', presumably each one has a different call?
