TQSL at L4OM shutdown
Is there a setting somewhere that will cause TQSL to close automatically once it completes a successful upload to LOTW?
Re: TQSL at L4OM shutdown
Rick what are you trying to accomplish. Not sure I understand your question.
Your TQSL program is not actually opening is it?
Yes, that's exactly what's happening, but I infer from your question that it shouldn't be doing that. I thought it was normal for the program. Do I have a setting incorrect? (I'm using 2.25.0.0 by the way)
KD0ZV wrote: 15 Dec 2022, 18:09 Rick what are you trying to accomplish. Not sure I understand your question.
Well you should not see anything happening. The TQSL stuff happens in the background. The only time I ever see TQSL open is when I backup or update a certificate.
